Can you export a Revit file back and forth between Revit 2023, 2024 and 2025?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
sofia_sivertsson
574 Aufrufe, 1 Antwort
[ The subject line of this post has been edited for clarity by @handjonathan Original: export revit file]
1 ANTWORT 1
Nachricht 2 von 2
jay_colcombe
als Antwort auf: sofia_sivertsson
Revit is not Backward Compatible so you cannot open newer drawing version in older releases.
Once a model has been updated to a newer release it cannot be a saved in and earlier release either like AutoCAD.
There are a couple of workarounds using IFC but not ideal
Backward compatibility of Revit with earlier releases of the software (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
