help needed. how can I draw this attached profile of railing
how can I make this rail turn smooth/continuous in Revit same as the sample attached
@Anonymous @barthbradley @ValentinaZusik
Solved by syman2000. Go to Solution.
you need to use a Landing Height Adjustment factor and Connectors.
Just post what you got. That would be easiest.
I would use curtainwall for the first railing. See sample and see if this is what you want.
how can i import this into my current project. It opens as a seprate project not as family.
kindly attach the family of curtain pannel as highlighted.
Just select the curtainwall and copy it (CTRL+C). Go to your project and then paste it in (CTRL+V)
