Custom Material Library - Missing Image Files
Hi there,
I'm working on developing a simple Revit template for a firm and one of the most important things to include is the standard materials and finishes. I've gone through and created a bunch of custom materials and then assembled those into a library.
When another user opens a project on their computer using the template, all the materials and material libraries appear, but all materials with an image in their appearance asset show up as a missing file. I was very careful to put all the material images on the shared network drive, as well as the library file itself. So all the images are accessible to be re-linked, but it's just a time-consuming process and kind of defeats the purpose of having a materials library.
Anything I might be overlooking? Is there a way to have a defined path to the material images built into the template?
Thank you
cbcarch
I'm not sure exactly what is causing yout issue, but---
Make sure all users machines have this setting pointing to the material maps location:
Options>Rendering>Additional Render Appearance Paths
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Thank you so much! That would explain why it was working on my program but no one else's.
Is there a way to build this into a template? Or is this something that has to be adjusted for every individual machine?
Thanks again!
cbcarch
Glad to help.
It has to be setup on each machine--I think there might be a way to push this out to all machines via the .ini file or a similar feature--will check into this.
Edit: You can set the path in the .ini file. See link below.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-C1EAD1F7-0897-4C04-9F0E-E5E4376AB6DB
A Group Policy might be able to push the .ini file to each machine. Check with your IT manager or research Windows Server/Group Policy.
Cliff B. Collins
