Hi, i have a big problem with linked model... I want to change linked model view template but i don't see all views from linked model. Where could be a problem? Thank you very much for help!
Views i can set:
Views in linked model:
Solved by RDAOU. Go to Solution.
The views on the second image (the missing ones) are of a different Type. In other words...If the main model view is a Floor Plan or a Structural (looking Down) you cannot set the Link to Reflected ceiling or Structural (Looking up)
That being said the Structural framing drawings Rzut konstrukcyjny need to be of a similar type to that in the main model view otherwise they will not show on that drop down list
In your current project template, did you checked on the view template linked view? I would check it off if you want each of those views to have different linked view.
