custom hatch pattern
Message 1 of 10
Hi Guys,
I'm trying to create custom hatch pattern but i always got  the pop up saying "no model pattern find"
here is my pattern.
;%UNITS=MM
;%VERSION=3.0
*Ceiling1, (2) 600 X 1200 (1)150 x 1200
;%TYPE=MODEL
0, 0,0, 0,1350
0, 0,1200, 1350,0
90, 0,0, 0,1200
90, 600,0, 0,1200
90, 1200,0, 0,1200
90, 1350,0, 0,1200
can you please help me figure this out.. thanks
Replies (9)
Message 2 of 10
Corsten.Au
You just need two lines for rectangular model hatch
try this
*ceiling 1200 x 600
;%TYPE=MODEL
0, 0, 0, 0, 1200
90, 0, 0, 0, 600
Corsten
Building Designer
Message 3 of 10
Thanks. But I also need to have 150x600 every 2 of 600x 1200..
Message 4 of 10
Corsten.Au
am not sure how to add another level to that.. but if you have a 2D hatch pattern
available which works,  then just add
;%TYPE=MODEL
to hatch pat file...
Corsten
Building Designer
Message 5 of 10
Corsten.Au
try this..and modify accordingly
;%VERSION=3.0
;%UNITS=MM
* Ceiling
;%TYPE=MODEL
90,600,600,0,1200
90,300,300,0,1200
90,0,0,0,1200
0,0,0,0,600
Corsten
Building Designer
Message 6 of 10
FAIR59
there is a mistake in the 2nd line definition
;%VERSION=3.0
;%UNITS=MM
*Ceiling1 _ (2) 600 X 1200 (1)150 x 1200
;%TYPE=MODEL
0, 0,0, 0,1350
0, 0,1200, 0,1350
90, 0,0, 0,1200
90, 600,0, 0,1200
90, 1200,0, 0,1200
90, 1350,0, 0,1200
Message 7 of 10
David_Knight
your hatch pattern is missing 2 digits from each line.
*edit*
take a look at this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Creati...
Message 8 of 10
David_Knight
Try these out...
Revit 2017 file and pat file attached.
;%UNITS=MM
*Ceiling,Ceiling Grid
;%TYPE=MODEL
0,0,1200,0,-1200,1350,0
0,0,0,0,-1200,1350,0
-90,0,1200,0,-1350,1200,0
-90,1350,1200,0,-1350,1200,0
-90,150,1200,0,-1350,1200,0
-90,750,1200,0,-1350,1200,0
Message 9 of 10
hugha
@FAIR59 nails ir.
Defining Revit fill patterns consisting entirely of unbroken lines such as this ceiling grid is not at all difficult
Open a text editor and put this at the top of a text file
;%VERSION=3.0
then for a pattern dimensioned in MM.
;%UNITS=MM
or, if dimensioned in inches
;%UNITS=INCHES
Then the pattern's name prefixed by an asterisk
*pattername
then, for a MODEL pattern  add this one line.
;%TYPE=MODEL
then, for each line in the pattern, add a line containing five numbers separated by commas.
1.   Angle from horizontal in degrees
2.   X co-ordinate of a point on that line
3.   Y co-ordinate of the same point
4.  the number zero
5.  line's spacing, measured perpendicular to line
Save the file with extension .PAT and load to Revit.
This is explained fully in the preamble to the standard pattern file Revit.pat distributed with Revit.
Note:  the free HatchKit Add-In for Revit. graphically creates patterns consisting of multiple unbroken lines directly within Revit projects.
hth,
Hugh
Message 10 of 10
Thank you guys for your help... Smiley Happy
