Custom Fill Patterns
Im trying to create a custom 'Fill Pattern'. but when i tried opening the "PAT" files all i saw was text & numbers. Is there a way to draw something & save it as a pattern?
Thanks.
hugha
Autodesk has always left this task to others such as HatchKit, hatch22, Pyrevit, pattycake and a number of AutoCAD-hosted generators.
The text and numbers you mention are explained in comments to be found at the head of the standard file revit.pat and discussed in more detail here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
If you post a description of the pattern you seek this board will probably be able to assist you.
hth,
Hugh Adamson
www.hatchkit.com.au
Pattycake_Kyle
Hey @Anonymous! - Check out www.pattycake.io
We built Pattycake to do this exact thing. With Pattycake you can draw directly in your browser, or use CAD to create a DXF file and upload it. We also offer 15 templates for commonly needed pattern types. No install required and not version specific.
Create a free login and you also get instant access to 400+ library patterns (which might negate the need to draw anything in the first place) 🎂 Happy Pattycaking!
Just Like ThisJust Like This
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
