Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
custom family sweep with parameters and or handles?
Hi all, i hope this finds you well.
i am trying to design a structure that will flow over the roof of my building, the form is very detailed and ultimately is a green wall system. below is a sketch of the idea. the brown tentacles are a 3D sculptural formed green wall system.Capture.PNGCapture.PNG
the idea is that what is constructed is a timber "tube" arranged on the rooves of my structure and it becomes a custom garden bed that can easily be adapted. cut a whole in the timber, put in the soil and plant a flower.
also as a cooling strategy for the building
what i need is basically to be able to take a sweep, and change point height so that i can make them flow.
that would be enough but would also love to be able change face sizes.
83646676_806534296531052_4817639033234522112_n.jpg83646676_806534296531052_4817639033234522112_n.jpg
i'm no pro but i'm also not an amateur, i just need some pushes into what i need to look at applying to a model, i've been trying to wrap my head around reference lines and and such but i'm not finding what i want. what kinds of tools should i try to achieve this?
if i find a solution i will be sure to share
chauh
Can you not create a beam family and adjust your vertical points manually? If you need spline like control I'd use an adaptive template.
