- Mute
- Permalink
- Report
I think I've found a glitch in color schemes, hopefully someone has the solution so I don't to constantly manage this.
So, we've created custom color schemes (changed the default colors) by room name and have applied them to multiple views. Great. Now, when someone goes to edit a different color scheme we are losing all of the custom inputs and it's reverting back to default colors. I've made a couple of realizations here:
1. When using the properties palette to adjust the color scheme you are limited by view to using the applicable category color schemes and there is no issue.
2. The only schemes affected seem to consistently be created with "Room Names".
2. When using the tool ribbon to adjust color schemes you have the option to use all categories available for color schemes obviously. When you navigate to a random category of color scheme and then back to rooms, the room name color scheme has completely lost custom color inputs.
I've tested this on multiple projects and the issue is the same. The only way we can edit our color schemes without losing the custom inputs on the room name scheme we have to edit them from properties palette.
Thoughts? This is incredibly annoying because team members constantly want to make changes through the ribbon and we are having to spend time fixing it every time.
