Curved Wall Finishes
- Mute
- Permalink
- Report
What is the best way to apply two seperate finishes to a curved wall? We have a project that's basically all curved walls that we modeled a while back, and now we're creating elevations and applying finishes, and it's a hassle. I know you can't split the face of a curved wall, which is ridiculous, this feature should be added in 2017. Using wall sweeps, you can't cut the face of a curved wall. The only other way I know, is using stacked walls. We have a bunch of different stacked wall types, that are three of the same basic wall types stacked on eachother, stopping and starting at different heights to accomodate the various finish heights we have throughout the project. We have to change every curved wall with two finishes to this stacked wall. The main problem we're having with this is when we change the wall type, any floors and ceilings that are connected to the wall using the "Pick wall" command, come up with an error saying they'll be deleted if we continue. So on top of changing all the wall types, we have to redraw the ceilings and floors using the "pick Lines" command.
If anyone has any input, or better ways to go about this, please share. In the meantime, Autodesk, please come up with a "Split Face" command for curved walls.
