Curved Ramps
Curved Ramps
hbjarch
Message 1 of 16
Curved Ramps
hbjarch
Revit seems to have trouble with doing curved ramps. Is doing a floor slab and modifying sub elements my only option?
Replies (15)
Message 2 of 16
Alfredo_Medina
Please be more specific. What curved ramp, exactly? Any samples, sketches?
Message 3 of 16
hbjarch
See the sketch attached. It' a vehicle ramp in a carpark. I presume the inside edge of the 1:6 portion will set the slope (ie when a cross section is taken through the ramp the ramp surface is level).
Message 4 of 16
Alfredo_Medina
Create 2 types of ramp, one for each slope. Use some reference planes in plans and elevation to determine elevations and distances. Use the level contraints and base offset values to locate the start and end points in the correct places. It is not difficult.
Message 5 of 16
hbjarch
Thank you, much appreciated.
Message 6 of 16
Hi
Message 7 of 16
Alfredo_Medina
Well, the ramp tools has a Run option, which includes an Arc option. Other than that, it's a matter of entering the settings for elevations and slope, etc, and creating the sketch.
Can that be a parametric family? Yes. But such family could not serve as host for railings. Only floors, ramps, and stairs can host railings, but we can't make families in those categories.
Message 8 of 16
So, assuming that I am done with the sketch, what do I do to save it as a parametric family? Do I save the whole ramp as a group or do I deal with them separately? Thanks alot for your reply!
Message 9 of 16
Alfredo_Medina
No, making a ramp and making a family are two different things that cannot be combined. Ramps are system families, and for those, we don't have templates.
Message 10 of 16
Hi Alfredo Medina,
Thanks for your reply, I guess I have found the solution to my problem. I wanted to create a custom ramp family so that it can be loaded into other projects. So what I did was I duplicated the system family and sketched the ramp out with the appropriate dimensions and gradient, I selected them and saved them as a group. When I open other project files, I was then able to load them as groups and then when I sketch the ramps, the "custom ramp families" was loaded with the system families.
Thanks again 🙂
Message 11 of 16
Try this link out, very, very helpful.
http://www.youtube.com/watch?v=5GaIarzxYPQ&feature=youtu.be
Message 12 of 16
atelierpv
Can you give me another link for the video because this one do not exist?
Thank you.
Message 13 of 16
m_jawad94
Community Visitor
Community Visitor
can anyone tell me plz that what is the minimum inner and outer radius on that ramp?
Message 14 of 16
Alfredo_Medina
Please consult a book such as Architectural Graphic Standards.
Message 15 of 16
chrisplyler
If you have the Tenth Edition like me, you can start on page 105. It occurs to me that I may want to update.
Message 16 of 16
jalalhamidi1365
Community Visitor
Community Visitor
Is there any posibility to give a cross slope to those ramps too?
especially to the curved one? or should drw as a floor then?
