I created a project with multiple linked Revit files in it and I'd like to rotate the models in their own files to be "North/South". I understand choosing between True North and Project North, but I can't tell which I'm supposed to rotate because when I rotate the actual model and bring it into the host file, it's not accurate. Am I to bring it in to the host and then rotate and move it into position and then publish the coordinates? I have tried that, but then when I go back to the linked file and import a AutoCAD background drawing by it's origin's, it doesn't line up.
Is there a tutorial online somewhere that describes the process for rotating a linked project file in its own file to be North/South and then import it to the host file and establish (publish) coordinates so everything works? Do I just need to re-export to AutoCAD to modify the origin point for the DWG file?
