Curved Mullions
Curved Mullions
Message 1 of 12
Curved Mullions
Hello everyone,
I'm currently working on a Honda dealership, and on their standard face they have a curved vestibule with two large storefront systems. On these storefront systems the top corners are curved.  I can't seem to find anyway to model this correctly on a curved wall ( On a straight wall this is easy cause the you can just edit the profile). Any help would be nice.
Thank you,
Chris
How it needs to lookHow it needs to look
Replies (11)
Message 2 of 12
Curtain System on Mass Face?
Message 3 of 12
This doesn't seem to work
Message 4 of 12
- Create a mass (or any type of 3d element) to define the boundary of the curtain wall
- Model the compound curved mullion as a model in-place sweep and pick path (the edge of the 3d form)
Message 5 of 12
I can create the curved curtain wall, the problem is the 36" radius at the corners, since I can't edit the profile on the curved wall.
Message 7 of 12
loboarch
Curtain system on a mass face will work if you use a void in the cylindrical mass to "cut" the shape out. Here is a quick example that i took about 3 minutes to make.
You will NOT ever get a true curved mullion. You will always get some kind of faceted thing approximating a curve. If you need a true curved mullion, you are going to have to manually build that and it will not be a "curtain wall".
I have attached a Screen cast showing how to use an in-place void to "cut" an opening in an arc shaped wall.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 8 of 12
This is a real booger.  What about In-Place Modeling?
Message 9 of 12
loboarch
Awww.... crap my screen cast did not come through.
Jeff Hanson
Revit Help |
Message 10 of 12
syman2000
You could do in-place family for everything. However if you want to create using Revit system family, use the roof extrusion. Create a wall with glass thickness and attach it to the roof. Next use in-place family and choose the 3d edge to pick the edge of the wall. SAMPLE.png
Message 11 of 12
I finally go the mullions to model correctly using mass face, but now that it's a system family it won't let me embed it in the wall. Currently my old curtain system is hidden underneath and that's what is creating the opening.
Message 12 of 12
Don't embed. Create a separate void to cut the wall.
