curved beam modelling
josemukalel
josemukalel
I was just researching why curved beam keeping slight distance from the required path ?
for example, i need to draw curved beam through blue line which is over the curved beam in the image, but once I pick on the blue line the arc forms slightly away from the blue line .any way to control this ?
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
SteveKStafford
It looks like the framing has an offset value, for Y Offset Value as an example.
Steve Stafford
Corsten.Au
1. Get the Radius Right
2. once thats done, its matter of " Start Level Offset " and " End Level Offset "
Corsten
Building Designer
