Can anyone help with creating a curved angled wall with a curve to the base. On plan the wall is curved and in section it is angled at 60 degrees. Where it meets the floor there is a 1m radius curve. I've attached a sketch to show this.
Using massing I can do the curved angled wall bit it is just adding the curve at the bottom I can't get my head around.
Has anyone got any ideas please?
Claire
Solved by dzanta. Go to Solution.
Solved by loboarch. Go to Solution.
You can use the sweep command to create this wall. Use generic model rfa family template file or use mass rft template file as a start point.
see revit file attached...
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thanks Dzan
That is what I need albeit the wall slopes in the opposite way.
Can you explain the steps as to how to make that please?
Decide if you want to do an in-place family (e.g theres only 1 instance of this wall or you wont need this shape again) or a generic family (Many instances of the wall, or need to use it again in other projects or something)
For in place go to the architecture tab - component - model in place - walls
Create tab - sweep
sketch path in modify tab - in ref plane sketch your line as in plan view (your sweep) - green tick that when youre done
back in modify tab select edit profile - revit should give you the option of going into a section view (north, south), choose one and sketch your section (your profile) as is in your section view. Make sure the corner of your profile is attached to your sweep then green tick everything and you should have your sweep, super simple.
If you want to create a family instead ignore the first line and instead new family - generic model or mass and follow the steps again
p.s I really wish i had screencast to show you but unfortunately my company dont let me install things
I'VE DONE IT!!!!
OMG the feeling is wonderful when something goes right in Revit. My friend and I who have been stuck on this for days have been dancing round the office with people giving us weird looks
I followed this tutorial http://www.revitzone.com/conceptual-design/144-forms-creating-a-sweep in order to create the generic mass in my template then I turned the generic mass into a wall using the wall by face under the massing tab. I just need to figure out how to put openings into it now.
Thanks for all your help.
