curve doesn't show in Dynamo revit
l.yong1
l.yong1
Please see attached
RDAOU
@l.yong1
That node only serves for selecting an element in the model it neither creates anything in Dynamo nor does it show a preview.
You have to add more nodes and develop the graph further in order to see something...like adding for example the node element.geometry, connect to select model elements and run graph
You can then toggle the preview option if you right click the node
RDAOU
@l.yong1
There are some elementary introduction to the basics which you can find on Dynamobim.org Primer https://primer.dynamobim.org/
These are quite helpful if you want to learn dynamo
RDAOU
Follow up..
@l.yong1  Are you all good on this one?
l.yong1
Not sure. I need more clearer steps. How to arrange one column on a curved path?
Thanks😎
RDAOU
@l.yong1
🙂That was already replied to on a different post...if this one is clear, you can close it off and we move to the other post.
