I tried to create a curtain wall panel with a panel component that's set at an angle. I thought, foolishly, that the easiest way to do this would be to snap the ends of a line based family to the intersections of planes that define the endpoints. Silly me.
I tried constraining the points to both planes but as soon as I changed the width of the panel there were constraint errors with one of the ends of the panel trying to separate from its constraining plane.
I drew a reference line between the points. This seemed to work fine as I could stretch the width of the curtain panel and the reference line's end points remained locked to the two intersections. I then aligned and locked the component to the reference line but when I changed the width I get another constraint error. Apparently the angle of the component is a stronger reference than the reference line.
My last hope was that at least I could use trigonometry and control the width of the panel by an angle parameter. I was warned by my BIM manager that curtain wall panels have no width parameter and when he had tried drawing information from a reporting parameter in a formula in one his families it wouldn't work. I held onto hope and tried setting it up but got no further than trying to establish a angle parameter between the component and a reference plane. The simple act of creating a parameter was trying to move the component away from the anchor point. At this point I gave up.
There has to be a way to do this.
