Uniform level
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
652 Aufrufe, 9 Antworten
Uniform level
Hello, someone can say me why level have different format and how can uniform them?
Thank's
9 ANTWORTEN 9
Nachricht 2 von 10
Sahay_R
als Antwort auf: Anonymous
Just click on the names that you need to change. You can then type and edit them to whatever you want.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 10
als Antwort auf: Sahay_R
Not speak about the size.
Have different size.
Nachricht 4 von 10
Level markers are annotation symbols...so they are set to always be the same size on paper.  So if you change the scale of a view to a crazy scale, they will look super small and you will probably want to change to a spot elevation instead of using levels.
Nachricht 5 von 10
Please can you see my pics attached before?
The wall have the same dimensions but the annotaction level in the second is unwachable.
Nachricht 6 von 10
Yeah, I saw the pics....what is the scale of the view in the 2nd picture?
The dimensions are going to stay the same regardless of the view scale...
Nachricht 7 von 10
Please try to view elevations project.
Nachricht 8 von 10
Sahay_R
Change the scale of the view in the second picture. That should make the levels readable.
Rina Sahay
Nachricht 9 von 10
This.
Thank's.
Nachricht 10 von 10
Sahay_R
Perfecto!
Rina Sahay
