Curtain Wall Mullions
bimitaly
bimitaly
I Have to create Horizontal mullion and on the top of it vertical mullions in a sloped Glazing roof. if create like the way one of the mullion getting spacing either horizontal one or vertical one which is i don't want. i tried may ways and checked the option but i couldn't make it.
For better understanding see the attached snip.
i need to make both mullions continues.
Thank you.
Satya Adabala.
Stack two sloped glazing roofs, one with hor million, one with vertical mullions. Or stack two beam systems.
hmunsell
Mullions in a curtain wall have a priority, there are 4 default options to choose from. Once set, you can modify each intersection manually if needed. BUT one always has priority over the other. Only other option is do as @ToanDN suggests.
Howard Munsell
bimitaly
Thanks for your reply.
 Actually i can't make two wall system. however i'll try to use stack two beam system.
if i encounter with any new issue i'll get back to you
Thank you.
