Curtain wall joining to roof issue
roscopeco2000
Message 1 of 10
roscopeco2000
Hello I am trying to get a curtain wall system to join to a roof but its not working i have tried using the edit profile setting but get the same issue. I get translucent grid come up but it will not cut the panels to an angle.any ideas thanks?
Replies (9)
Message 2 of 10
Sahay_R
Select the curtain wall, and then Modify>>Attach Top / Base. Then select the roof.
All else failing, please share a file.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
Custom panels will not cut it, only rectangle shape You need to either model odd shaped panels in place or family with void, or using adaptive family.
Message 4 of 10
roscopeco2000
yes this is what i have tried and it didn't work see attached file..
Message 5 of 10
Sahay_R
Is this a 2018 file? Rats. I only have 2017!
Rina Sahay
Message 6 of 10
roscopeco2000
ok makes sense but this is a kingspan model i would have thought they would have modelled it with that in mind. What about if i did a cut on the wall panels to cut the angle in?
Message 7 of 10
roscopeco2000
yes 2018 time for an upgrade 🙂
Message 8 of 10
You can try but I think you will have a hard time cover different angles and dimensions. Other options are using curtain mullions, or a beam system. Basically each mullion or beam is a rib.
Message 9 of 10
roscopeco2000
its a shame the kingspan panels are not set up to be adaptive as you mentioned there're a big company i would of hoped they would..
Message 10 of 10
analuiza.duarteOliveiraVRFFL
Make a normal wall where the curtain wall should be, attach it to the roof, than change the type to curtain wall
