Curtain wall issue
Curtain wall issue
Sahay_R
Mentor Mentor
Message 1 of 15
Curtain wall issue
Sahay_R
A team mate is attempting to insert a curtain wall into a masonry wall type and the curtain wall would not cut through the masonry wall. However, when I attempted to duplicate the situation on my machine, the curtain wall was able to cut through the masonry wall successfully. Now again I am trying to duplicate the situation on my other machine - and am getting the same results.
At first I advised to clean up the computer - delete locals, temp files, restart, etc. Did not help. What could be wrong?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (14)
Message 2 of 15
Revit_Whisperer
Not all curtain walls are set to automatically embed ( a type parameter of the curtain wall).  The one that is is the Storefront curtail wall type.
You can use the cut tool (on the modify menu,Geometry panel) to cut the opening around the curtail wall though if it is already drawn in the other wall.  Select the wall to cut then what to cut with.
Message 3 of 15
Sahay_R
Hi @Revit_Whisperer we are using the Storefront Curtain Wall. Sometimes it works, sometimes it doesn't on the same type of wall in a different location. Sometimes when the same wall is copied and placed in a different location the curtain wall will / will not work. Scratching my head here.
Rina Sahay
Message 4 of 15
Revit_Whisperer
When you draw it make sure that you see the wall centerline show up to snap to or you will have the issue you are seeing
Message 5 of 15
Sahay_R
No go. Cut didn't work, Snapping to centerline didn't work.
Smiley Sad
Rina Sahay
Message 6 of 15
Revit_Whisperer
If you start a new project does that happen too?  If not could be some sort of corruption...hard to say.  And I guess make sure that the embed checkmark didn't get removed on the storefront.
https://www.screencast.com/t/c1ftVRbwhnZ8
Message 7 of 15
Sahay_R
Embed checkmark? What have I missed?
(suffering a bad case of the Mondays)
Rina Sahay
Message 8 of 15
loboarch
It is a type property of a curtain wall.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 9 of 15
Sahay_R
Embed checkmark on. This is a brand spanking new project being created to replace the old model.
Here's what I did to test - in the same project view, I drew a random wall, copied the properties from the 'bad' wall, dropped a storefront wall in there - and it cut. When I tried on the wall of the model (and I'm in the same file same view still) it DID NOT work. GRRR....
Rina Sahay
Message 10 of 15
Sahay_R
Also - neither can she, nor I, make the curtain walls obey. But the team member at the other end of the building can (and he has been told to continue the good work - no one will feel neglected >:)) !!! So creating new walls / a new Project may not be the answer!
Rina Sahay
Message 11 of 15
Hello
is the masonry wall made by you or one of the existing types in the template ?
Message 12 of 15
Sahay_R
It's a custom wall type.
Rina Sahay
Message 13 of 15
So he was able to embed the same curtain wall in the same wall but you was not?  Or was it for another location?
Message 14 of 15
Lance.Coffey
Autodesk Support
Autodesk Support
Would it be possible to attach a small sample RVT that demonstrates the behavior (e.g. copy problematic wall(s) into a new file)?
This way we could take a closer look at the way the wall/project is configured.
Lance Coffey
Technical Support Specialist
Message 15 of 15
Then the problem is most likely adjacent building parts. Any walls connecting to the one you are working with, either above or below?
Also, since this error does not exist on all work computers, the error is most likely instance-parameter-based.
Our in house BIM-expert often says: "Revit never does something which you do not tell it to do", and so far i haven't found one case where he hasn't been correct. 😉
