Curtain Wall Door
Curtain Wall Door
Message 1 of 21
Curtain Wall Door
I did not create this family, and I think it's a bit over my head. It won't adjust to the height of the curtain panel. Is there an easy fix? I like how the rest of it functions for me... Thanks.
Replies (20)
Message 2 of 21
I don't have Revit right now but you can try to lock the geometry of the door to the top reference plane in the family.
Message 3 of 21
already tried, doesn't change a thing.
Message 4 of 21
Sahay_R
Try this. Now the panels adjust to the frame.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 21
i am in 2014...what did you do? i'll try to replicate it. unless you have 2014...
thanks!
Message 6 of 21
Sahay_R
For some reason, the frame didn't like the top reference plane. I
1) removed the existing constraints - the Height dimension and the lock on the frame
2) created a whole new top reference plane,
3) locked the top frame to it
3) dimensioned the height and gave it the Height parameter
Rina Sahay
Message 7 of 21
thanks. that worked. one more question. i tried putting it into a large opening, but for some reason the door panels don't flex in size...see clip. thank you.
Message 8 of 21
Sahay_R
Remove the Width dimension from your family. Leave the parameter.
1)
2)
Rina Sahay
Message 9 of 21
my width parameter is reporting, and i can't modify it.
Message 10 of 21
Sahay_R
There is a little pencil at the bottom left of the dialog box. Highlight Width, and click the pencil. Yes you can edit reporting parameters and remove the reporting - I did that for the height.
Rina Sahay
Message 11 of 21
if i remember correctly, that's a "new" feature...2014 kind of sucks. and the more i look at this family, the worse it is. i guess i didn't get the height to work, yellow line is where it is, and green is where the curtain wall stops. and in elevation it only shows the door open...so, i'll try something else. but thanks for trying to help.
Message 12 of 21
Sahay_R
Click on one of the panels. Make sure that Panel Height in the panel family is associated with Panel Height in the door.
Rina Sahay
Message 13 of 21
One more thing to do.
1.   Make "Height" parameter to be Shared
2.   In Project, load the "Height" Parameter in the Project parameter section.
Otherwise it won't read and flex it.
Hope this helps, Dan
Message 14 of 21
Sahay_R
Some thing that might be helpful, since curtain wall doors are a pain -
Recreate the family. Use the door family template, nest the panel families, apply the parameters as have been shown in my previous screenshots. This will give you significantly less grief - trust me on this.
Rina Sahay
Message 15 of 21
I'll try that, thanks.
Message 16 of 21
You cannot create a family from a door template and insert it as a curtain wall door. It must be created using the curtain wall door template. You can nest other families in it to create the folding panels to control the array more easily.
Message 17 of 21
Sahay_R
@ToanDN - what we have been doing is to replace the curtain wall panel with a wall, and then drop the door into it. As a result we no longer have curtain wall doors in our library. They were too much of a pain.
Rina Sahay
Message 18 of 21
What sort of troubles do you have with curtain wall door families?
Message 19 of 21
Sahay_R
Not sure - they date to WAY before my time. Suffice it to say that here in my organization, Curtain Wall Doors are a dirty word......
Rina Sahay
Message 20 of 21
But I need doors folder containing multiple choice. Where from I download library/doors of Door*.raf files
Thanku
