Curtain Wall Corner Mullions
14 REPLIES 14
Message 1 of 15
6879 Views, 14 Replies
Does anyone have a functional 45degree Corner Mullion family, for joining 90 degree walls.  I can edit it.  So don't worry about the exactness of it.  I am making a Kawneer 1600 corner.
Thank You
Nardo
14 REPLIES 14
Message 2 of 15
Download it through the Manufacturer's link to BIMObject.
...here's one: http://bimobject.com/en-us/kawneerna/product/21014
Message 3 of 15
in reply to: barthbradley
I see normal components there on the "BIM Objects" site, but I don't see a corner mullion.  Please check the image below.  If you have a link to such a file, that would be great.
Nardo
Message 4 of 15
You need to drill down into the Project Browser. They are both listed there.
Kawneer-1600_LR_7-14 Mullion_V-Corner and Kawneer-1600_LR_7-14 Mullion_L-Corner
If you want it modeled more accurately, then you will need to build the family yourself. You can pull Architectural Details from the Kawneer website to guide you, but keep in mind, this is what they mean by "over-modeling". My advice: save that LOD for Details.
Message 5 of 15
I'm building the Curtain Wall Model for the Manufacturer.  So further detail is required.
I've seen such mullions in live models before.  But I wasn't at the helm.  So I couldn't check and see if it was a modeled in place element.  That's what I normally do.  I'm trying to expand my library of functional stuff that works like it should.  These corners are popular.  I'd like to have one that I can just edit to the specifications of my detailers for each project.  The ones I have modeled from scratch always have some issue.
Thanks.
Nardo
Message 6 of 15
stingers80-cgarchitect
Just wondering if you found a good way to make that corner mullion?
Message 7 of 15
See attached.
Message 8 of 15
in reply to: ToanDN
Do you have this file available in 2018 version?
Message 9 of 15
in reply to: ToanDN
How do you get the horizontal mullions to cut properly? I had already created my own corner mullion, but neither horizontal, to the right or left, cuts properly.
Message 10 of 15
Is "Corner Mullion" checked?
Message 11 of 15
No, it's greyed out.
Message 12 of 15
Message 13 of 15
in reply to: ToanDN
Thanks~ Works great on the border horizontals (top / bottom) but not on the intermediate horizontals.
Message 14 of 15
Works fine on any horizontal mullions.  You need to play with toggle mullion join a few times.
Message 15 of 15
in reply to: ToanDN
Ah ok, yes. I was using the "toggle mullion join" control on the mullion segment. When I select both segments and use the Make Continuous command, they join properly.
Great~ Thank you! I have a much simpler curtain wall system now.
