I tend to use the CTRL+mouse drag to copy elements a lot. Just force of habit coming from other platforms. Lately in Revit 2023.1 I've realized that I've been losing keynotes as an example when I use the CTRL+Drag command. I was finally able to recreate the issue. When you CTRL+mouse drag Copy and then use the scroll button to pan outside that area you lose the original element or keynote in this case. I know it did not use to happen before. See Video below. Hopefully it makes sense.
