Cropped View Error on Sheet
melissahRSS8X
Message 1 of 8
melissahRSS8X
I have unit plans with complex crop regions. When I place them on sheet, model elements (except rooms and room bounding lines) disappear. They still show on the drawing if I open it separately from the sheet, and they print correctly. They also show when the crop region is reset. I attached images of the 3 scenarios.
I can think of several workarounds, but I think this is a bug. Can someone at Autodesk help me out? I'm using Revit 2017.
Replies (7)
Message 2 of 8
This is very strange indeed - especially the part about it printing correctly. In other words, it's printing MORE than WYSIWYG.
Anyways, first thought went to worksets. Could it be correlated?
Message 3 of 8
Can you share the file?
Message 4 of 8
RDAOU
@melissahRSS8X
Are are the disappearing elements part of a group or a linked files?
If yes; add a scope box and make sure a line of the scope box runs through that/those view(s) / cropped regions. That should do the trick regardless how complex or funny the region is...
PS: someone told me I shouldn't write too long text so that's as short as I can make it 🙂
Cheers,
Message 5 of 8
FGPerraudin
Hi @melissahRSS8X,
We have had the same issue at the practice.
Basically after trying and trying again to find a logical answer to the problem, we cropped just a little bit larger / off the walls/objects/alignments (we were strictly aligned with the walls), and it worked.
Wasn't a temporary bug though as it would happen again if cropped strictly following wall boudaries.
Maybe this little trick can solve your issue as well.
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Message 6 of 8
I have seen instances where custom crop regions result in some views not printing even though the views are visible on sheets. I have seen this in both 2016 & 2017, less so in 2017 though. Are you up-to-date with all your service packs?
Removing the custom crop always resolves the issue for me. Your problem seems to be a weird hybrid. The fact resetting the crop resolves this issue in both instances, I feel indicates that custom cropping may still be a bit buggy.
Message 7 of 8
melissahRSS8X
It's definitely not worksets. Resetting the crop region makes it reappear.
Message 8 of 8
melissahRSS8X
Some elements are part of a group and others aren't. Adding a scope box doesn't resolve the issue/
