Create a standard filled region for this often called upon application.
I call mine "whiteout" and I use invisible lines for the border.
As Steve will be quick to point out... make sure that you choose "no
pattern"
- just solid white....otherwise you may have plotting issues.
wrote in message news:5239717@discussion.autodesk.com...
Thanks Steve for your prompt reply , we are using the scope boxes to control
the linked files also and as you know we can not delete the text from linked
files in the host file , as these text will also be applicable to other
zones and areas, any thoughts.
many thanks.
