Crop View
Crop View
e234606
Crop View
e234606
Hey guys.
Am new to revit and whenever I open a new file, it has a crop view, section line, scale and other thing on there. I dont mind the others that much but my problem is the crop view. It limits me to view the whole entire plan am working with.  Can someone please help me know how to disable it. The only option i see is with hiding it, but its still active even then. Thanks
loboarch
You can hide the crop region or turn off the crop region. Hiding leave its effect on but removes the edge. Turning off completely removes all cropping effects. Use the two controls on the View Control bar to do this.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
e234606
Thank you so much.
But when I cant use "Do not Crop View" for some reason its not highlighted. Like I cant click on it, might  you know the reason for that?
loboarch
Yes, that is a new template we started shipping this year. It is supposed to help folks but in this case it is makign things difficult. That cropping control is grayed out because the view is assigned to a "scope box" (long ecxplination).
To be able to control this by yourself, Go to the properties of the view and set the "Scope Box" property to "None". Now the control is enabled for your use.
Jeff Hanson
Revit Help |
e234606
Thank you so much, this has been really helpful
HVAC-Novice
Thanks for posting this. I used Revit many years, and totally ignored those buttons. I just always unchecked the "Crop View" in properties when I had the need to not crop.
I'm just glad I'm browsing this forum, learn something useful every day.
Revit Version: R2026.3
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
