Crop region, DWG link and printing
cyrankam
cyrankam
When printing view cropped with non-rectangular region, cropping does not seem to have proper effect on text in linked DWG. Please see attached image.
Probably yet another bug, but maybe there is a way to make it work.
dferreira-blackwell
the crop is for modeling element, turn on annotation crop and you will see the range text will be visible. Typically annotation crop is bigger then plan crop as visible from your pics. Annotation crop cant be changed to non-ractangular form it will stay rectangular regardless of plan crop.
cyrankam
As i mentioned above it is not annotation object. It is a DWG link. Plus as you can see text is being cropped by crop view, just not as it should.
dferreira-blackwell
yeah, seem a problem in Revit.
crop viewcrop viewprint resultprint result
