Creating window schedule to show actual windows on sheet
woodstim
woodstim
Does anyone know how to create a window schedule, showing each window on a sheet?
I was shown once but cant remember. , so i can dimension them etc.
I want to have a sheet that will have my windows shown on it.
Thanks.
Create a snapshot image of each window type and associate an image to each type via Edit Type. Add Type Image field to the schedule. The images will show when you place the schedule on sheet.
Something like this:
But it sounds like you want to use Assemblies.  Select a window and Create Assembly, then create Assembly views and you can annotate the window without seeing anything else.  Then place the views on sheet.
