creating wall by face - Please help!
Message 1 of 17
Hi everyone! I'm new here.
I'm having some troubles making wall by face using a mass. So I want to create something like this:
 I created a mass but when i want to make walls, it becomes distorted:
 Can someone help me with this please?
Replies (16)
Message 2 of 17
post the mass you made.
Message 3 of 17
here it is:
Message 4 of 17
What are your challenges?
Message 5 of 17
I think what you are seeing as distorted, is only the  over-layed mass . Turn it off and with is what remains.
Message 6 of 17
I want a void in the middle. Thats why I'm seeing distortion.
and I tried turning "show mass" off but it didnt change.
Message 7 of 17
_Vijay
dIdi miss something?
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 8 of 17
how did you do this? mine looks so bad!
Message 9 of 17
martijn_pater
Just looks like a thinner wall type used...?
Message 10 of 17
_Vijay
Here is the file...
Vijayakumar
Head of BIM
Message 11 of 17
@Anonymous: the screenshot I posted is Walls AND Roof applied to Mass Face. It is "hollow" and the Roof can be removed.
I think the problem you may be having is two-fold: 1. The Mass is Visible and causing what looks like a distortion. If so, you can turn the Mass Category OFF (Do Not Delete). 2. The Wall Location Line changes the shape of the Wall by Mass Face (e.g. Wall Centerline, Interior, Exterior").  Finish Face: Exterior works the best IMO.
Message 12 of 17
lucdoucet_msdl
@Anonymous
In the example image, the shape in the red markup is a double curved surface as its base (if you follow the grid lines of the model) has both convex and concave profils. As for the top, it appears to be a horizontal plane but could easily be sloping at a small angle from the horizontal. Your massing family is a loft thru 3 flat but parallel profils.
Then there is the matter of the thickness of this surface. What end condition are you interested in: a horizontal cut versus an plane that is perpendicular to the surface at the edge?
In your approach, the wall families hosted on the faces of the lofted surface have top and bottom edges that form a variable angle with the top and bottom planes. Revit seems to have some value for this angle that determines if the end face is cut horizontally or perpendicular.
If your intention is to reproduce this complexity in the surface, I would suggest.
Lastly, is it critical that the result be a wall family to what purpose (hosting openings, attaching to a roof, sceduling quantities)?
In the case you also want to pursue the mesh like quality of the model, I would recommend looking at divided surfaces and adaptive components. Here are two good sources:
Buildz (Zach Kron): https://www.youtube.com/watch?v=POND315utnY
Balkan Architect: https://www.youtube.com/watch?v=_ADPVGzj6y4
-luc
Message 13 of 17
lucdoucet_msdl
Please disregard this incomplete sentence. :-0
Message 14 of 17
bin
sometimes you just need a thinner wall.
Message 15 of 17
How do you mean?
Message 16 of 17
bin
Message 17 of 17
Just curious.
