Creating Toposolid from Point Cloud
GregHanlon
GregHanlon
Are you able to create a Revit toposolid directly from a Point Cloud or I need to convert to DWG or CSV?
_Vijay
Hi @GregHanlon ,
there are a few add-ons to do that. However, if you want a clean topo, better clean and create dwg and then insert to Revit.
here is one that might help that I used before. also, you can use the cloudcompare to clean and clear dwg for free.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
GregHanlon
Thanks @_Vijay , I have used Scan Terrain in the past as well but it only works on Toposurfaces; not toposolids. I haven't tried this but, in theory, you could use that add-on in 2023, make a toposurface, then copy it into a 2024/25 model and convert it to a toposolid. It feels weird but might work.
_Vijay
yes it will work. i have done like that a few times. 🙂
Vijayakumar
Head of BIM
eleanna_panagoulia
I thought 2025 can create a toposolid either from CAD or CSV, so unless you use third party plug ins, like Environment, you have to convert to .csv.
