Creating sheet without border..
roscopeco2000
roscopeco2000
I am creating a drawing sheet template, the company i work in don't like a visible border. This is causing me issues as there's no guide to show the extent of the drawing, this there a way round this??Thanks
Kimtaurus
Draw the border the exact same size as the sheet, it won't be printed (if your settings are correct).
Or draw a border using invisible lines or reference lines. These won't print, but will give you a detectable sheet.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
roscopeco2000
I've tried invisible lines but these show up in the family but not in project. I will try the lines the size of printable area
RobDraw
Guide Grid
Rob
