Thank you for your kind reply, RNDPIS.
I do know how to do that, I was looking for how to import actual USGS data not having surveyor data, just for early draft purposes. I could not get the USGS data in a format that Revit could use (it may be possible, but I was not able to locate a supported file type on the USGS interactive elevation download site. AutoCad will provide some conversions but I don't have the AutoCad suite). So I kept looking for a way to get some actual elevation data to work with. Google Earth is less accurate than USGS so they say, but still, it is actual data which what was needed.
I found a great YouTube video that shows how to use the free SketchUp application to import Google Earth rectangle, or meshed multiple rectangles elevation data with image layer. Command is File > Geo-location> add location which will allow you to find a specific location on Google Earth. You can then bring the file into Revit. Rhino not needed even though the presenter uses Rhino in the YouTube. Took me two minutes.
YouTube link to Topography from Google Earth: https://www.youtube.com/watch?v=Hk_sQun48X0&t=316s
