creating dormner with face flush with wall below
Message 1 of 8
I am looking for help on how to create dormer similar to the attached image. I understand how to create a dormer when it sits farther back on the main roof, but I am not able to create one when the main wall continues up to form the face of the dormer.  Can anyone help?
Thank you.
Paula
Replies (7)
Message 2 of 8
constantin.stroescu
Hello Paula,
It is not very clear for me what exactly you want..
Is it something like this?
Constantin Stroescu
Message 3 of 8
I'm equally confused. The dormer tool is used to cut a hole in the roof that is below another roof (a dormer roof). In other words, the tool is used when you're working with 2 roofs; on overlapping the other. Your picture shows 1 monolithic roof; there is no dormer condition here. If you want 2 roofs sharing the same exterior wall, but with one located at a higher plate height, then model 2 different roofs on 2 different plate heights (e.g. wall heights). Then use your dormer tool.
Edit: see attachment...
Message 4 of 8
The image you attached gives the exact hints that you need.
Message 5 of 8
constantin.stroescu
I think I understood wrong,  and you want , in fact, a Flush Dormer...something like this:
If so, then , have a look on my screencast:
Constantin Stroescu
Message 6 of 8
Thank you so much! This is the solution.
Message 7 of 8
Thank you!  Your screencast was very helpful.
Message 8 of 8
davidtetro
YES! Thank you! I have been spending the last 10 years butchering my roofs trying to get this to work.
