Creating an octagonal skylight
Sahay_R
Mentor Mentor
Message 1 of 16
Sahay_R
This is what I need to create. The skylight sits on a wall 1'-0" high.  The footprint is octagonal.
I am trying to start with a mass, so that I can create curtain walls by face. How do I create the mass? Or is there a better way out?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Accepted solutions (4)
Replies (15)
Message 2 of 16
Octagonal? Looks like 10 sides (Decagonal).
Why not  apply Sloped Glazing to a Decagonal Mass?
Message 3 of 16
Sahay_R
That too, @barthbradley. Generating the octagonal mass is the problem here. Idiot-proof directions, please.
Rina Sahay
Message 4 of 16
Place a Decagon on 1 level and another smaller Decagon on another level directly above it, select both Decagons and Create Form.
Message 5 of 16
Sahay_R
Oh brother - I did it again. Found the solution. Thank you @barthbradley for reminding me of the magic words Sloped Glazing....
https://www.cadlinecommunity.co.uk/hc/en-us/articles/204332112-Revit-Architecture-2016-Creating-Slop...
Rina Sahay
Message 6 of 16
That looks like an Octagon but a couple of faces are splitted.
Message 7 of 16
Sahay_R
But @barthbradley, what I  want is an octagonal pyramid with a pointy end. What you suggest is a truncated octagonal pyramid (ie no pointy end). Please elucidate for my education and edification- even though Roof By Footprint has already granted all the wishes of my little heart.
Rina Sahay
Message 8 of 16
Draw it as a roof by footprint and change it to sloped glazing type.  I see you have mentioned it so I am surprise you needed to ask.
Message 9 of 16
constantin.stroescu
for a Mass, you can, also use, if the edge are equal, a sweep : a Profile - a trapezoid shape place in the center , and a path that consists of the base an eight sides figureImage 1.png
Constantin Stroescu
Message 10 of 16
What??? You can create, as I described, with the smallest "pencil point" you want.  1/32" tolerance in Revit. Anything smaller, you need a physicist.
Message 11 of 16
this method (sweep  triangle in this case ) allows Pyramids
Constantin Stroescu
Message 12 of 16
Sahay_R
@constantin.stroescu - maybe I'm missing something - when I tried to sweep a triangular profile for a Generic model in place, Revit gave me a very very rude response saying something about intersecting geometries - hence the questions....
@ToanDN - I posted the question before finding a solution. A simple case of Think Before You Click.
Rina Sahay
Message 13 of 16
constantin.stroescu
I used Conceptual Mass not Component Model In Place.....Even in Mass Editor the word sweep does not appear, in fact that is a sweep...isn't it?
Constantin Stroescu
Message 14 of 16
It works also with Component Model in Place , but you have first to create a vertical called Reference  Plane through the center of the octogon  and use that plane to place the shape....
Constantin Stroescu
Message 15 of 16
constantin.stroescu
it works in both cases.....
Constantin Stroescu
Message 16 of 16
Sahay_R
@constantin.stroescu - THANK YOU! Those were totally idiot-proof directions!
Also @barthbradley - I followed your way very successfully too - with a teeny-teeny circle at the upper level.
Aaahh, the wonders of Revit!
Rina Sahay
