Creating a Section without creating a section view
I would like to know if revit can create section marks (as show below) without actually creating a section. I was thinking about creating a symbol but seeing if there is another option before i try. Thanks
dzanta
if you use the default section marker annotation, you can set the section marker to not create a view and associate it to a drafting view (which you can leave blank)
if you just want to create a section marker symbol with no parametric/bidirectional capability, then just create a new annotation symbol using the generic annotation family.rfa file.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thank you for your response. I did make a default section mark which populated views in Drafting views, but i do not want these views created in my project browser.  If i create a new section mark symbol am i able to make it smart? For example, i know i can add labels into the symbol but i would like to make it so i can control the length of the section like you can with a regular section mark. Is this possible??
dzanta
you should be able to create the annotation symbol with basic geometry (lines, circles, hatching, etc.) and then parameterize the length, radius of circle, etc.)
