Creating a Roof with Different Eave Heights -Trouble
Message 1 of 11
Greetings,
I was following the instructions for Creating a Roof with Different Eave Heights (Link)
But got trouble with the procedure when joining the two roofs, because you need to pick a line and a surface, and that is not there in the instructions.
How can i do the roof in the link? (Image below)
Accepted solutions (3)
Replies (10)
Message 2 of 11
mariano_biagioli
Hi, the link in your coment isn´t working.
Are you using the Join/Unjoin Roof tool?
Here is an example to use it with diferent eaves heights
Please, if the answer helped you, mark it as a solution 😊
Message 3 of 11
constantin.stroescu
your Roof can be done from a single Roof by Footprint.
The result is this:
Constantin Stroescu
Message 4 of 11
Offset from Roof Base. Then add overhang as Roof by Extrusion.
Message 5 of 11
constantin.stroescu
Message 6 of 11
Sorry, the link was: https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revi...
They do the procedure joining two roofs, however, your answers were very helpful, thanks for your time.
Message 7 of 11
Do you want to mark mine as the accepted solution as well, since it was the same as @constantin.stroescu?
Message 8 of 11
Sorry, I missed it, thank you very much
Message 9 of 11
veeresh.huvinahalliACK3L
How to can we create above same roof with different pitch value given to the plate height value?
Message 10 of 11
How can we use above same solution with scenario for non defining slope line.
Message 11 of 11
