Creating a Revit Family with 2 Host Walls
Morning All,
I am currently trying to create a Wall Hosted Generic Family in Revit 2018 that I can host to two individual walls. The purpose of this family is to host an external panel to two walls at a 90 degree angle.
Please could anyone advise me if this is possible.
David.
Setup a reference plane to where the 2nd wall should be.  I've done this quite often when I have a corner window and I am using voids to cut out the walls.
Morning,
Thank you for this method. Please could you attached an example of a corner window that you have created?
David
hi, you can try to do it with curtain wall
