Creating a Line Based generic family that replicates instances of a component without an array?
MMuchmoreEPVRP
MMuchmoreEPVRP
Hello, I am trying to create a family that will act as a stand in for a metal panel wall's finish face allowing me to modify the finish material on a per-panel level while avoiding using split faces or running multiple wall types with different finishes in series.
A problem I am running into with line based generic models and model-in-place solutions is that when the component is arrayed I can not change the material on a per-component level, even with the paint material tool.  Is there any way to keep the level of editability I need while still using a line based model?  Is there anyway to replicate components in series without the use of an array?
Sounds like curtain walls should be able to accomplish what you are after.
MMuchmoreEPVRP
I have found that curtain walls don't join or interact with basic walls in the way I need them to, they also pose a challenge at windows and door openings in basic walls.
Can you show screenshots of joint or interaction, and challenge at doors or windows that you are not happy with?
