Creating a drawing issue sheet
steven.steel
steven.steel
I am trying to create a Drawing Issue sheet within Revit.
I have hit a wall with tracking the previous Revisions issued, E.g. T, T1, T2 as the project progresses.
has anyone had any experience with this?
My plan was to create a number of yes/no parameters for sheets and then create a formula to "+1" with a prefix of "T" for example, but I’m struggling to be honest.
Below is a snip from Revit showing my failed attempt.
Below is an example of our old fashioned excel drawing issue sheet format, that im trying to replicate in revit.
Not clear what part you failed? Adding the prefix?
yordan.vakarelov
Hey there! Struggling quite a bit with the same issue at the moment so I just wanted to check in and see if by any chance you have found a solution to this? In its most basic form, if anybody else is reading this, we are looking for a way to track each revision (T1, T2, T3 for example) and add it only to the date it has been issued, as well as the current revision. Is it going to be a problem to share your attempt as I am not sure how to even make the check boxes! Thank you and I hope you have managed to pull it off!
Yordan
peter.besley
WHY is this not standard functionality in Revit.
