- Mute
- Permalink
- Report
Hy everyone. I am trying to create a curved panel with this parameters:
Height
Angle
Radius
Thickness
Until this part it is working fine. But I need to insert a lot of holes on the base and on the top, needing the parameters:
Number of holes (the angle at the ends need to be the half of the internal angles, it is working with the proper formulas)
Height of the holes line
What I have tried:
1 - Creating the solid and the voids in the same file.
The array and parameters work fine but I can't control the height of the holes line, because I can neither align the groups nor the array itself with my reference plane.
2 - Creating a hole family face based and loading into the panel family
I can insert on the face, but the array doesn't work properly (because of the curved face, I think)
3 - Creating a hole family without host and inserting into the family of the panel.
I can't cut the panel with this void.
Any ideas?
TIA
