Create Toposurface from Import - Contour Lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a multi-project site that is halfway through development and I have been tasked with creating the 3D siteplan for rendering purposes, including walkthroughs of the entire site. As it is still in development, it is changing frequently, so I am attempting to create a 3D cad file with contour lines we can use to easily control/update the surface as needed. As much as I would love to just get the TIN from the civil engineer, that is not currently an option. The current method works extremely well for our purposes... except when it doesn't.
The problem is that Revit seems to place points at MOST of the polyline vertices, but decides (arbitrarily?) to ignore some occasionally in key locations. Adding vertices does not change this behavior in these locations. Does anyone know how Revit chooses where to put points when creating the surface, if not at each vertex? And/or does anyone know of a way to force points at the desired locations without manually adding them afterward?
