Message 1 of 13
Create toposurface from CAD file- Elevation
Hello all,
I have a .dwg file with the cadastral plan in elevation zero and also some points in an elevation around +800.0m, from which I want to create the toposurface in Revit.
When I import the .dwg file in Revit and create the toposurface, I have a distance of (800m) between the building and the toposurface.
If I move the toposurface down, the points lose the absolute elevation value that they have (after is quite difficult to calculate the slopes that I need etc.)
Which is the workflow that I need to do in order to avoid this problem?
I want when I import the .dwg file in Revit to be in the elevation of my building in order to create the toposurface in the same place with it.
What you will do in my situation?
Thank you in advance!
