create rotated construction/sketch planes ?
cekuhnen
Mentor Mentor
Message 1 of 22
cekuhnen
How can you rotate sketch planes in Revit so you can create pipe structures like legs for a chair which are not going
along the typical xyz directions?
In Inventor or Fusion 360 I would create a sketch plane at an angle and thats it.
I noticed that for example all Herman Miller furniture products are rebuild right inside Revit utilizing such rotated planes.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (21)
Message 2 of 22
cekuhnen
here for example are some screenshots:
you can see the sketch/working plane clearly being at an angle
and it looks sketching in Revit is so cripled that one needs to offset the start and end profiles fromt the sweep path to get the look of the part being sweeped along a true 3d path.
Claas Kuhnen
Message 3 of 22
scott_d_davis
Create Reference Lines in Revit.  Ref Lines are different from Ref Planes in that they have start and end points and can be drawn in 3D space. Ref Planes are drawn in planer views, ie plan, section, elevtion.
Scott D Davis
Sr AEC Technical Specialist
Message 4 of 22
cekuhnen
how can you draw it in 3D space? I can only draw 2D reference lines.
Claas Kuhnen
Message 5 of 22
scott_d_davis
Start a new Conceptual Mass Family, place a Ref Line with the 3D Snapping option turned on.
Conceptual Mass editor is a bit more powerful than other family types
Scott D Davis
Message 6 of 22
cekuhnen
The mass editor can be used to also make furniture families?
Claas Kuhnen
Message 7 of 22
Alaaeldin_Alsahli
Mass element can't be use within the family since you have the option to creat solid forms.
My question for 3d refrence plane, is your family a build-in family or a loadable family?
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 8 of 22
cekuhnen
I am not sure if I follow your family question. What are those two family types you mentioned?
All I need to figure out is how I could create a pipe system like in this screenshot:
As you can see the Path in rhino is not planar and goes into all 3 directions. To build this in Fusion I have no clue how to do.
Break it up into 3 sections for each planar part a sketch plane on their own and how the ends will later line up?
Claas Kuhnen
Message 9 of 22
Alaaeldin_Alsahli
Did you create the family from Revit-new-family and you are modeled it and then it is loaded into the project (loadable)
Or
you have an open project then you went to the architect tab--Component--Model in place (build-in)
just wanted to be sure you family is loadable or build in family
Alaaeldin Alsahli
Message 10 of 22
cekuhnen
I build a family so architects can load the furniture file into their scene.
Claas Kuhnen
Message 11 of 22
Alaaeldin_Alsahli
I am uploading a video that will show you how to do this path in Revit, it should be ready in 5 mins
Alaaeldin Alsahli
Message 12 of 22
Alaaeldin_Alsahli
I hope this will help you, Please watch it till the end since I had an error message while selecting the path what I had to do to workaround it
https://screencast.autodesk.com/Main/Details/342c2342-c037-45ed-9c3c-78a456361657
Alaaeldin Alsahli
Message 13 of 22
Alaaeldin_Alsahli
Just a follow up if this helped?
Alaaeldin Alsahli
Message 14 of 22
cekuhnen
Hi Alaaeldin,
Yes the video helped - confirming that also Revit like Fusion or Inventor are rather 2D planar sketch engines with features lacking the ability to really sketch in 3D space like in Rhino or Alias.
The video showed a process I was using as a workaround before but as it seems this is currently the only way I even have to do it.
Thank you very much!
Claas Kuhnen
Message 15 of 22
Alaaeldin_Alsahli
I guess if this feature is in Revit no one will buy Inventor 🙂
Alaaeldin Alsahli
Message 16 of 22
Alaaeldin_Alsahli
You could always log a wishlist for this feature
here is the link
Alaaeldin Alsahli
Message 17 of 22
cekuhnen
well Inventor and Revit serve different needs but how am I as a designer supposed to rebuild my furniture for architects / interior designers when Revit is pretty basic at this only when it comes to forms which are not planar. ...
Claas Kuhnen
Message 18 of 22
cekuhnen
the link does not work
Claas Kuhnen
Message 19 of 22
Alaaeldin_Alsahli
Revit is not design to create detailed element. Usually Revit Family should be less complex and simplified to help Revit to handle the entire elements within the project to optimize its speed. More details the heavier revit goes.
Where Inventor is more of a detailed design, where everything needs to be created from scratch, from part by part to an assembly.
A detail chair like the one you propose should be created in inventor unless is simplified
Alaaeldin Alsahli
Message 20 of 22
Alaaeldin_Alsahli
it is wierd that the link is not working, try to google autodesk feedback form and you should get the first result as the link
Alaaeldin Alsahli
