Create plinth as 1 element that is separate from eachother
gianni.fostier
gianni.fostier
Hi!
Your English is mostly correct, but there are a few minor improvements that can be made for clarity. Here's the revised version:
Hi!
I need to create multiple plinths in a model. In my case, it's important to be able to select one plinth for each room. In some rooms, the plinth is not connected to each other due to the presence of a window, door, or another obstruction. Therefore, using a railing element is not possible as I receive an error message stating, 'The railing line must be a single connected sketch.
I understand that it's easy to draw multiple railings, but in my case, I need a single connected element with a unique ID.
How can I accomplish this in Revit?
Thank you!
jvpantin2
Use wall sweeps:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-54122AE4-F009-42FB-8670-D665598A5A46
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Can you post your file...or at least some screenshots so we can follow along?
