Create Parameter using other parameter value
komchan.prakaiborisuth
Hi guys is there anywhere to create a new parameter to display other parameter value.
Example:
Type Name: FH1
Type Mark: SSW01
Diameter: 50mm
I want the new created parameter to show the value as "FH1 SSW01 50mm".
If you just need to tag them then  add these parameters to a label.  If you want a true parameter then you need to use Dynamo.
