Create floor from excel points
qchenTPPXV
qchenTPPXV
Greeting,
I have couple points from Excel, x, y, z values. And I  need to use those points for the to of the floor. Any ideas I can do it in Revit directly. I know that I can create a surface using these points in Civil 3D.
jay_colcombe
You would need to implement Dynamo for this!
https://forum.dynamobim.com/t/slab-from-survey-points/75634
Jay Colcombe
Autodesk Certified Instructor
Try to create a toposolid from import and choose that file (you need the export it from excel to csv or txt format).
qchenTPPXV
That's a good idea. What if I also have some points for the bottom of the floor. Do you think it would work?
