Create/Customize Leader Arrowhead
ChrisGamble
Message 1 of 26
ChrisGamble
There's no way to create or customize a leader arrowhead right? Arrowheads are under graphics, there's no way to get to the graphics parameters or files where the arrowheads live and modify them?
Replies (25)
Message 21 of 26
ChrisGamble
You seem excited. Read your last comment. I had already accepted the answer that it is not possible as the solution, and was only going back and clarifying my original post, then you posted your comment.
Message 22 of 26
Your clarification post is yesterday.
Today you posted again and the first thing is "So how would a I add a custom arrowhead to a tag?".  My comment is to respond to that very post, not the one you posted yesterday.
Message 23 of 26
ChrisGamble
@ToanDN wrote:
No you can add any custom arrowheads for tags, symbols, keynotes, texts.  But, you can use a detail section mark with a custom tail instead of the floor tag.  It's better anyway because you can reference the UL detail to the section mark instead of manually typing it to the tag.
Message 24 of 26
@ChrisGamble wrote:
Here @ChrisGamble, you can replace with this one. I'm not using it at the moment.
CANNOT
 Smiley Wink
Message 25 of 26
jesus_tecuapetla
según la imagen que  estas enviando la  parte baja la puedes editar en este archivo, solo dale click derecho Edit.
solo da
Message 26 of 26
derek_harris
@barthbradley @sorry to revive an old post but i was looking around reading up on creating custom tick marks for arrowheads, which i'm clear on now. NO you can't do that yet.  however i ran across another post of yours where you helped someone with a stair issue and you posted a screen shot (attached) with what looked very much like a custom tick mark to a Stair Direction arrowhead.  I have not been able to achieve and arrowhead like that with the baked in options for system families, so i thought it worth asking you how you did this.  Was it something i'm missing about the system families, or did you use some custom Generic Annotation family instead of the automatic stair arrows??  Any thoughts or advice appreciated.  Cheers!
