Create Column Schedule Level wise
In scheduling of Column Material Takeoff, I would like to show the client how much material goes between different levels in the same column - that is material volume and estimated reinforcement Volume. It's ok even if I have to break the schedule level-wise, probably with filters. What's the most efficient way you would suggest?
Create Parts from columns, split Parts by levels, and schedule Parts.
Or, create column material schedule and add Calculated parameter to calculate the volume based on level height (manually entered to the formula). Duplicated the schedule for other levels and change the formula accordingly.
Dear @ToanDN,
Impressive thought as always 🙂
Volume based on level heights entered manually works really well. Saves a good time.
