I am very new in using Revit and need to create a 3d Trihedral (Tetrahedron) in Revit, is there any mass sample for it to share with me? Or any clear guidance to create it?
Zahra
Zahra
Solved by constantin.stroescu. Go to Solution.
Are you talking about this:
Diagnostic Tripod-1 point.rfa in the Mass Folder of your Library. There are 4 types.
Hi
Thanks for your reply.
I am looking for this shape, I have the 3d model of the bridge, and want to add the 3d model of the trihedrals.
Zahra
Hi
Zahra
You need to model it yourself. That's not a "stock" component. Either as a Loadable Family or In-Place Component (or Mass).
you can use a swept blend to do make a 3D triangle.
Howard Munsell
Howard Munsell
...several other ways that could be used in order to achieve your purpose:
1.
https://knowledge.autodesk.com/community/screencast/9e4e805e-761f-42b7-981f-2dc0ec1ba090
2.
https://knowledge.autodesk.com/community/screencast/c90b490b-c36a-4c6b-9435-041daba74434
1.
Constantin Stroescu
1.
2.
1.
Constantin Stroescu
is this what you are trying to model?
See the attached RVT. If it is what you are after, I'll clean it clean it up. It's pretty much fully parametric, but needs a few additional constraints.
...play around with different "W" Values. For instance, try 4'-0", 5'-0", etc.
..and what I think to be a more elegant solution is to use:
https://knowledge.autodesk.com/community/screencast/67f2682d-a878-474d-b9cc-a739b9e53852
Constantin Stroescu
Constantin Stroescu
ooh, I see now! I thought the OP was showing a rhombic triacontahedron - a polyhedron built around the dodecahedron. (he, he)
groovy Trihedral/Tetrahedron, @constantin.stroescu.
Turn on, tune in, drop out.
Hi constantin.stroescu,
Awesome, Should be very helpful, I am going to test it now.
Thanks very much for your prompt help.
Zahra
Zahra
Thanks for your solution, It worked, but sounds constantin.stroescu's solution is more reliable.
Zahra
Zahra
Hi Constantin,
Could you please advise me how I can remove the base plane of the trihedral? to be seen like attached picture.
Zahra
Hi Constantin,
Zahra
you mean to make only the 3 side faces but not the base face?
If this is what you want, then from my previous posts:
1.using Mass family - two methods shown in my screencast
2. or even using a very thin Roof by Footprint with Modify Sub Elements
As for the Component Model in Place it can be done by changing the Profil into a thin Trapez instead of a triangle.
Constantin Stroescu
Constantin Stroescu
Hi Constantin,
Many thanks, it worked very well.
Zahra
Hi Constantin,
Zahra
Hi Constantin,
Sorry, it's me again! Many thanks for your kind support.
I've made the trihedral model as a family using your "Component Model in Place" solution and loaded it to the 3d model of my bridge. Now the orientation of the trihedral should match to the reality, I have the angle between side-planes and the West/East plane of the bridge, and the angle between the base-plane and the horizontal. For making the first one, I defined a reference plane in the one of the floorplan views with a right angle w.r.t the bridge East surface and then pick that reference plane for the trihedral, so you can see the results in the attached pictures (floorplan and east elevation view of the bridge project). But, my issue is orientation of the base plane w.r.t the horizontal. Could you please advise how I can set this? I tried rotation in the south elevation view, but sounds it doesn't do what I need.
Zahra
Hi Constantin,
Zahra
I've been researching this question as well. I was able to create a trihedral using an extruded triangle, a void sweep along the hypotenuse of the triangle, and some trigonometry. The family is attached.
