Create a Template file from A360 Project
steve
steve
I can't create a template file .rte from a Revit project stored in A360.   I have tried to
  1. save it to local.
  2. Close and re-open the saved to local source .rvt
  3. relinquish all ownership in closing
  4. open with "detach from central" of the local file.  Saved to new name (revit appends "detached_" to the file name automatically,, btw)
  5. deleted / unloaded everything in "manage links"
"Save as template" is still grayed out, can't be done.    What am I missing?
Thanks!
Save the cloud model to your computer somewhere and close it.  Open a detached version and save it as a template.
RobDraw
A workshared file cannot be saved as a project template. You need to detach from central and discard worksets. May also have to save as a different project and reopen before saving as a project template.
Rob
steve
discarding the worksets was my missing step.  Thanks!
RobDraw
You're welcome. I'm glad YOU solved it.
Rob
RobDraw
So, this is a thing with you? Taking credit for other people's solutions.
SMH...
Rob
